zorcy
- April 24, 2006
- Acworth, GA
- 95 XLT 4x4, loaded
It stopped. Just gave up the ghost. Checked the clutch, seems fine. Had some build up on it, so i cleaned that. Saw some oil and carbon, so I cleaned that off, too. Looks like grease coming from the shaft onto the clutch. Too thick to be ac oil. With the ac on, I could not feel a pull on the clutch coil. Checked the ohms, the coil is fine. I checked gas, she is still full of freon. Checked power at the coil, she gets 14, so its coming from the alternator, not the battery. Odd thing about the the ground side of the coil, it has about 5 volts.
Not sure if it matters, but I have had some controls issues. Max AC is the only setting that will not let the heating core get hot water. Regular AC has the compressor running, but the valve is open and hot air blows, just like defrost on heat. Was thinking about re-routing the vacuum lines to a higher vacuum.
