shansen1
- November 12, 2007
- Portland, OR
- 95 XLT
95 4.0 won’t start, good fuel pressure, plenty of spark, fuel pump runs continuously, PCM is not enabling the fuel injectors, any ideas? No codes
I have checked the wiring, relays, fuses, grounds, etc and everything looks OK. The fuel pump is new and is delivering 30 PSI fuel pressure. Whatever is supposed to shut down the fuel pump and activate the injectors is not working. There are no trouble codes since the battery went dead and was disconnected for recharge. After reinstalling the battery, the ODB2 analyzer says it cannot connect. This could be an indicator of the problem because something in the circuit is keeping the ECU from sending signals to the injectors?? There is plenty of spark, and if I use starting fluid it will start and of course die again because of the injectors are not firing. There is power to the hot side of the injectors.
I started getting desperate so I changed out the fuel pump, fuel filter, PCU, coolant temp sensor, with no help to the problem…help!!
What in the world can cause this?? PFE?
