mactaz000
- January 11, 2006
- Deltona, Florida
- 95 EB 4x4 Stock
Just wanted to begin with many thanks, I have saved much time, $$ and many brain cells due to the information contained in these pages.
1995 EB Explorer 4X4
OHV V6 Stock 220k
4R55E rebuilt 15k miles ago by recomended transmission shop with updates.
Very light towing-small 5x10' dump trailer a couple times a month moving my quad.
Mostly used on highway to and from work. No use of 4x4 due to another issue.
Transmission stopped shifting on my way home.
Found fluid all there, but, burnt and smelly.
Changed fluid and filter (new gasket-Mercon V), pan had black sludge covering the magnet, no parts or chunks. Reassembled and confirmed fluid level (level, hot and cold) but still no shifts. Will engage from park to drive/reverse/D2 and D1 and drive normally, just no shifts and no 1st gear engine breaking. Flashing OD Off present. Codes pulled were 522 (my shift indicator in the dash is offset to the right of the chosen gear) and 335 (Pressure feedback PFE or EPT-signal voltage higher or lower than expected)
I ordered and installed a rebuilt valve body (all new Bosh solenoids, bonded plate, Ford upgrades...) thinking that the solenoids must be malfunctioning due to excessive heat from the catalitic converter (I sit idle alot) and low coolant (leaky hose to the overflow and low coolant in the radiator-since fixed). Engine never overheated but looks like the transmission fluid did.
No improvement after reassembly and disconnecting the battery to reset the computer, except, I have yet to see the flashing OD Off light when testing.
Still will not shift out of 1st when in drive. 2nd works when in D2. Reverse is ok as well. Same codes showing as well.
Should I mention that I have an issue somewhere between my key and the starter relay? For two weeks prior and currently I have to jump the relay to get it started (I feel like I'm stealing it or at least look like I am). This also means that I am unable to complete the key on engine on part of the OBDI code pull.
Your help on this will be greatly appreciated. I've searched and found similar issues but no resolve yet has been able to help me.
OHV V6 Stock 220k
