slow-demon
- September 28, 1999
- Hawaii
- '91 xl sport
Did anyone ever try installing a '95-'97 4.0L OHV (non sohc) enigne in a a '91-'94 explorer. I have read that the '95 and later 4.0L had a heart shaped cylinder which was smaller than those of the '91-'94 cylinder heads. That had the same compression ratio because of different sizes of dished pistons. The newer style '95 and later heads had was of a "fast burn" design. They also said that if you install a '95 and later head and block into a earlier '94 and older engine electronics the engine will not run right. Did anyone ever do this swap with sucess. I have a '95 engine that I want to install into my '91 explorer which has 188,000 miles.
thanks
thanks
