acsthacker
- January 29, 2010
- Adolphus, Ky
- 1995 XLT 4.0
95 Explorer, with a 94 4.0L. Check engine light has been on ever since I've had the thing. My initial problem was some sputtering when holding a steady speed of 35-45 mph, or lightly pressing the accelerator. A few people told me it was the EGR valve, so I bought a new one and attempted to replace it. Stay with me here, and I know I know, some of my procedure could have been better, but I was pressing for time and wasn't thinking. The EGR valve for this thing has two mounting bolts, then a metal tube coming from the exhaust into the bottom half of the valve. I removed the vacuum line from the top of the valve, removed the two mounting bolts, then tried to break loose the bolt holding the exhaust tube on with a crescent wrench. It would not move at all, though the line started to just barely twist to where the valve would hardly line back up to replace the mounting bolts. I did not break or crack this tube at all. I decided I didn't have the time, leverage, or tools for the job, so I tried to replace the mounting bolts. I could just barely get one back on... the other would not line up at all. I tightened the one down, cranked the truck, and idle was terrible, along with horrible fuel consumption (obviously). O/D Off was also flashing on the dash now. I took it to a shop to have the valve replaced professionally, and when they got the new one on, it ran the same horrible way. You can smell the gas from it flooding and at some point it smokes somewhat. They ran the codes on it, and found EGR OPEN, THROTTLE POSITION OUT OF RANGE, and 3rd Gear ratio incorrect or something. Thing is, when they cleared the codes, the truck ran perfect. Then within 20 seconds, threw the codes again and ran bad. Cleared the codes again and the truck perked right back up. Threw the codes again and ran bad again. Five mechanics have looked at this and aren't sure what to tell me. One said it was the throttle position sensor, but why would that go bad all of a sudden while I was changing the valve? Or anything else? It seems like a problem that happened so fast that it's gotta have a simple fix for it. Lemme know what your thoughts are.
