95 Explorer Started, Cut off and won't restart | Ford Explorer Forums
superanglia
Henrico, VA
1995 Explorer
This morning our 1995 Explorer started, ran for a few seconds, then cut off and wouldn't restart. It has about 155,000 miles on it. It was full of fuel and had power. The starter seemed to be okay. Any ideas?
Could be the relay for your fuel pump - Im not exatly sure but I think that is in the fuse block under the hood by the master cylender. Somebody will come in soon and correct me or add to that
I have a 95 XLT too, Check to make sure your fuel pump shutoff switch was not tripped, you might have just used what fuel remained in the lines when you started it. Should be located underneath passenger dashboard(below glove box underneath the floor carpet.
