95 Ford Explorer starting problems. | Ford Explorer Forums
Cindyclw
Henderson,Md
1995 Ford explorer
My Ford has been acting up, when it gets low on fuel it sometimes won't start. Today I went to the gas station and it wouldn't start after I put it half full of gas. Ended up pushing the reset switch and it started. It started after that but when I shut it off it would not start for 30 minutes. Finally got it by using the switch again. Sometimes it works some not, I have changed fuel relays repeatly and still it does this. How can I tell if relays are blown and if inertia switch is bad? My brother thinks its the brain but I don't think so. I also have had the wiring harness(recall) installed from the dealer and wondering if it is wiring problems. I don't want to spend a fortune but I am going to call repair shops tomorrow! I always get home eventually after being inconveinced then it decides to start. Does anyone have the same thing?
welcome
