95 front end help and opinions! | Ford Explorer Forums
Tat2dExploder
Monroe, Mi
'95 Sport 4.0
ok i know i just posted about my wheel bearings... sorry for postin again... but my whole front end is jacked up... power steering leakin, steering is hard and sticks in certain spots, got the death wobble goin on, tires sittin funny, ball joints bad, wheel bearings bad, brakes are bad... this bad boy has 180,000 miles on it and everythign is original, except for brakes... so i know i need a new rack and ball joints also... starting to wonder how i should go about this... if i should do it all at once? if it is worth it to do it all at once... or what? i'm open to any suggestions... thnx for the input fellas
I think a few members here have steering racks lying around from doing their solid axle conversion. Bet you could get one cheap from there.
Wheel bearings are cheap and eay if you're 2wd. Get those done, along with the brakes. Then align it and see how bad you are off. Ball joints may be inevitable.
i have a 4wd... how bad of a job is that? and if you know anyone with a rack lying around lemme know :)
I have a 95 XLT 2WD that is making a loud rubbing noise. It is supposed to be the front bearings. I was told at the Ford dealer that the bearings come as a complete assembly with the hub. Is this right? Does anyone have the OEM part number? Where do I get these cheap on the internet?
Thanks a lot,
Arturo
Arturo,
The 2WD are not sealed assemblies. I did my bearings a few times when I was 2wd. There's an inner and outter bearing. There pretty cheap if I recall. Something like $8 a piece plus a $5 seal. It's a pretty easy job.
section525 said:
Arturo,
Thanks alot man!!!!!!! You just made my day. The dealer wanted $500 USD per hub assembly!!!!!!!!!!
I will desasemble my hubs and look for the bearings alone.
Take care and thank again!!!!!
Arturo
section525 said:
Arturo,
Sorry, you mentioned a seal? What kind of seal? Did you get all this at the dealer? If not, could you provide me with the contact info of your supplier?
I ask you this because since I am in Mexico I don't know if I can get all this as you do in the US.
Thanks a lot again,
Arturo
