95 to a 92 will driveshafts enterchange | Ford Explorer Forums
pak8850
Iowa
1992 ford explorer
can anyone tell me if the drive shaft of a 1995 explorer wil fit a 1992 I have a wrecked 95 and want to use the good parts of witch I have some. sorry i did mean the rear driveshaft. I have used the four wheel drive motor already
thanks
i am sorry i should have put more info they are both 4 door and they both look the same i was just wondering if anyone might know I am putting the wrecked 95in the garage next to the 92 so i guess it will not be to hard to find out
I believe it should interchange no problem. But if you have a 2nd gen 95 the 4wd motor is only a 2 position motor and your transfer case motor is 3 position.
iam not sure what the 95 is but the motor has been working for a fey weeks although i do hav a very bad vibration it feells like it is in the whole truck i do knot you do not fel it in the steering wheel. and there are some bad u joints on the back so i would like to putthe driveshaft from the 95 on it and then rebuild the 92
Well there were 2 different versions of the 95 year there is a first gen version and 2nd gen version and the 2nd gen version the t-case shift motor is only 2 position...but if its working for you.
thank guys and sorry for double threading but all is good the driveshaft worked, So for the people that was having bad vibrations but not in the steering, it ended up being the rear u-joints
thanks again...
