95' XLT Windsheild wipers & Radio not working | Ford Explorer Forums
joebuck
California
'95 XLT
I was attempting to install a new radio deck in my car a while back. It was working well once I had everything plugged in, until somehow I accidently let the grounding wire hit the power wire for the radio. At first I thought that I had simply blown a fuse, but I replaced them and it did not work. a few days later I found that my front windshield wipers and rear license plate lights also do not work. I was wondering if anyone has any Ideas as to how I might go about finding where the problem is at and fixing it, or if you have experience with this type of problem, where it is located and again how I might fix it.
Thank you
you need to check all your fuses... chances are you took out one that you didn't "look" at.
I checked all of the fuses again today and they were all good. I also used a volt meter to check to see if current was even getting to the fuses and it was. Any other guesses as to what the problem might be?
