96 4.0 ohv 4X4 $2500 | Ford Explorer Forums - Serious Explorations
Birdy
Richland Hills, Texas
1997 5.0 XLT, 96 4.0 ohv
It's my daily driver, just bought a 98 4.0 OHC that I'm replacing it with. Everything works on this one. 2" body lift twisted and shackles extended for another "1.5. Run "33s when off-roading, but will be selling with 31 inch mud tires that are in excellent shape. Winch and cb do not go with it. The winch mount I fabricated, is welded to the frame, so it's basically part of the frame now. It has the axle disconnect, so I welded the front diff and put a switch in for the disconnect, so you can run without the axle locked. Pretty clean truck with new ball joints recently, and no sway bars anymore. I will throw in the sway bars and another carrier for the front axle in case you don't want the welded diff. Got 160 some odd thousand miles on the odometer. I'll get more pics posted, it won't load more than one for some reason.
