96 b2500 | Page 2 | Ford Explorer Forums
96 b2500
this is where i need to add some frech steel...
(pick stolen from the web)
Local junk yard got a ranger bead. . Would it be bolt on?
If its bolt on it would be less Job than the rust. ..
They want $350 for it with a broken tail light
Fighting the rust.
Need to get the hitch of so I can get the last 2 bolts that holds the bed out:eek:
Got the bed of last night..
The Ranger bed i found at the local junkyard was 15cm shorter than my bed,, so it will not fit.. so i need to fix mine.. :mad:
some progress:thumbsup:
Think i will just do a quick fix now.. plan is still to get a fresh bed:rangertan:
Bed is back on. ..
Hope to wire the lights tomorrow :thumbsup:
Quick fix just to get through inspection tomorrow. .
Hope everything goes good:thumbsup:
I did not pas.. more rust needs to be fixed :mad:
Love the rust. . Lets try inspection again :D
Boght a part truck today ( pick it up next week )
Its a 2001 Ford Ranger 2.5l turbo diesel.
I will use the engine and the bed. . Maby the axles if its ford 8.8 / D35
Got the part truck home today + I bought a set of 31's bfg at for the mazda
Think this will look good.. just need to find some 15" wheels:thumbsup:
Not bad for 500NOK ($61)
Finnaly got my brake calliper for the drivers side.. (from a junkyard)
Now i need to hunt down 2 calipper slide bolts.. Not the same calipper on the Ranger:mad:
Why not just build this truck, instead of swapping in the engine, bed, and axles. It's newer and looks in better shape than the Mazda...
Simple.. the Ranger is from sweeden, and i live in norway.. that meens ****loades of taxes (Norway is the nr 1 in the world on taxes) to just let the gowerment know the truck is on this side of the border:D
and the frame on the ranger is rusted to pieces.. i'm afraid if i flex the truck it will brake.. hahaha
i might put the super duty axles under it.. if i can strengthen the frame easy
Got a set of 31's bfg at on the mazda today :bounce:
