96 Explorer tranny issues. | Ford Explorer Forums
jfug97
rogersville, MO
92 XLT
I have a 96 4.0. The tranny was rebuilt by previous owner, the TC was not put on correctly and the flexplate broke, now the TC is stuck on the shaft, what is the likely problems with the tranny now, and how can it be fixed?
how hard is it to replace the pump?
is it hard to remove the bellhousing, and how much does a pump cost?
Everything is bolted on. It's not hard to remove. You will need a pump alignment tool to align the gears. The bell housing might need a new bushing. This has to be given out to a special place which has a lathe just for this purpose. The bushing is machined in place to be concentric.
thanks for the response.
