96 loosing oil pressure + lifter noise | Ford Explorer Forums
glued2it
Tulsa OK
96 xlt
I have constant lifter noise and Fluctuation in oil pressure
I figured it's the oil pump and then somebody told it could be the bearings.
So I figured I would consult with the Explorer experts here!:salute:
So what's the damage doc? :roll:
pressure should be 40 - 60 psi at 2000 rpms. what is it??
how long since last oil and filter change??
it could be either of the things you mentioned.
I just changed the oil tha's the problem I'm loosing oil but it's not dripping on the driveway. So I never check the oil level. first thing I did was check the plug and filter. I seen some oil down there so I pressure washed it and haven't seen any signs of leakage.
I figure out where it's going unless it only leaks when I'm driving
