96 XLT V8: Tripmeter/Odometer Fails, Speedo OK | Ford Explorer Forums
YamahaRick
Metro ATL, Georgia USA
1996 XLT 5.0
To get trip/odometer working 100% once again, what should be done?
While I'm at it, are there any attractive alternative speedo/tach/etc. faceplates I should consider?
Current odometer reading is 217K; probably close to 5K short right now.
There's a small plastic worm gear that deteriorates
from heat and breaks. A company called odometergear
sells a replacement gear to fix it. Cost is about $25-30
if I remember correctly.
They have a website with instructions on how to
replace the gear.
Or grab a junkyard unit, easier to swap if you don't want to do the gear...
Could grab a 2001+ Sport whiteface cluster...
They have a website with instructions on how to replace the gear.
Wow, the procedure is easier than I anticipated.
Thanks for the link. I plan to order a new worm gear and get it installed soon.
You're welcome and good luck with it.
I replaced to worm gear no fixy. I replaced instrument cluster no fixy.
Speedo is fine but no odo. Is there a sensor on the tranny?
Did you put your new worm gear into replacement instrument cluster?
Good luck, and drive safe.
Here is the service manual. For a 97, but should be the same (96 not as detailed). VSS I believe is on the transfer case. There may be two VSS if you have 4x4.
The odo uses the speedo signal, so that is weird.
