Naftaturbo
- September 19, 1999
- 1997 Ford Explorer
Update:
I replaced the fuel pump with a new Delphi. Fuel pressure with engine off is about 20PSI, and for the few seconds that the engine idles it is about 40 PSI. Fuel flow is good. Idles smooth, then dies after a few seconds of idling.
CEL is on with KeyOnEngineOff. CEL goes out while cranking. No codes.
Could sure use some help/suggestions.
Truck sat for about 3 months because radiator started leaking and I had to have surgery and then recover. Truck was running very well when I shut it down to remove radiator.
. Doc said I could start working again so yesterday I replaced radiator and checked for leaks.
. Tried to start truck and it would fire and run for about 3 seconds then die; noticed that fuel gage showed empty (apparently someone siphoned fuel out). Put in 4 gallons of fuel and same symptom: fired and ran for ~3 seconds then died. No OBD codes.
. Removed connector from inertia switch so I could run 12V directly to pump (pink/black wire). Now engine ran for about 20 minutes which allowed me to check cooling system at temperature and pressure and confirm no leaks. I backed truck out of driveway and parked it on the street.
. I let truck cool off for about 20 minutes while I cleaned up and was going to drive it to gas station to fill up. When I tried to start to drive to gas station the same problem started again. (Note, I'm still running 12V directly to pump through the inertia switch connector).
. Borrowed a fuel press gage from Auto Zone. Connected to Schrader valve on fuel line. Pressure builds up to 40 PSIG. Crank engine, fires for about 3 seconds then dies; during the 3 seconds fuel pressure holds at 38-40 PSIG. When the engine dies, pressure continues to hold at 40 PSIG.
. If I hold throttle wide open (stops signals to injectors?) the engine will fire and run up to ~3000 RPM then start to die off. If I feather the throttle I can get it to stay running (stumbling) a few more seconds and even idle for a few seconds. Fuel pressure stays at 38-40 the whole time.
. I then tried to do an engine off (12V to pump) fuel flow measurement by using the gage set's pressure relief button and draining into a quart container - I was going to time how long it took to fill. As soon as I pressed the relief button the pressure dropped off to about 10 PSIG with ALMOST NO FUEL FLOW.
. I'm now in a quandary:
(a) no fuel flow through the relief valve into the container and a drop in pressure (the pressure came up again when I closed the valve) I guess indicates the pump is bad (pressure but not enough flow) and the engine isn't getting enough fuel to even idle. But
(b) Since WOT causes it to run few seconds longer (and at high speed) when the injectors get no signal (should be closed), I'm wondering if an injector or two might be stuck open, not closing due to dirt, or some other injector issue causing engine to die due to excess fuel (flooding rich)? Still no codes.
. Anyone had a pump that delivered pressure but at such low volume that engine wouldn’t run? Since pressure stays at 38-40 for the few seconds engine runs (and stays at 40 when engine dies) I’m thinking this is a long shot…
. I don’t think its IAC because even if I open the throttle a bit when engine starts, it still dies off…
. Open to ideas and suggestions. PLEASE!
