tcross8361
- June 25, 2005
- Illinois
- 97 Eddie sohc 4.0
Ok, I posted this problem in the wrong section before so I'll try it again. My explorer is stuck in 4H. I unbolted and unplugged the transfer case motor and ran a jumper to the battery. The motor was working fine. So I plugged it back into its wiring harness and when I turned The ignition back on the motor turned back to the 4H position. I left it unbolted from the transfer case and went through the 4 wheel drive ranges using the dash switch and it did nothing. So My conclusion was it was a switch problem or in the wiring some where. I also checked the number 4 mini fuse under the hood and the number 26 on the side of the dash, they are both good. So where do I go from here? Is there any relays tied in with the 4 wheel drive system that I don't know about? I really don't think it is an internal transfer case problem at least till I get the switch working. But I don't know much about these explorers. I've only owned it 7 mos and its my first one. My last was an 89 ranger. I tell you I really went against my better judgement buying an electronic 4wd. so, if anyone can help I sure would apprieciate it.
