97 explorer brake problem | Ford Explorer Forums
CMattM42
Owensboro Kentucky
1997 explorer
I have a 97 explorer that the rear brake line above the rear end housing is leaking. I have never had to replace one of these and could use some help on how to do it. Thanks
I just replaced the main brake line & the 2 lines on the rear axle that go to the wheel cylinders on my 2000 Ranger. The main line runs from a fitting under the drivers side back to the hose that runs to the rear axle. I used Nicopp line, it was easier to bend & flare. I also had to purchase a brake line flaring tool.
http://www.jegs.com/i/JEGS-Performance-Products/555/635800K/10002/-1
This is the one I bought.
http://www.amazon.com/OTC-6502-Mast...8-1&keywords=OTC+brake+line+flaring+tool+6502
