1994 ford explorer brake problem | Ford Explorer Forums
everaragon
aurora colorado
i have a 94 explorer 4.0 and for some reason when i turn to the left side and step on the brake. the break seems to get stuck when i first step on the pedal then like 5 seconds later the break kicks in. i have changed the master cylinder and the ABS module. help what kan i do????
Is there any noise associated with this? Try to remove one of the ABS fuses and then see if the problem still exists.
Hmm, if it is associated only with turning, I would start by watching the hoses on both front brakes, there is a chance that a hose may have one extra twist in it or something is getting kinked when you turn.
Have a buddy turn the wheel full turn in both directions and watch that the brake hoses from the caliper to the frame don't get inturrupted.
You could either do that with tires on, or with floor jacks and the tires off to really see if you can identify the problem.
