unbwogable
- June 2, 2011
- Flat Rock, MI
- 1997 Explorer XLT
Pulled my dash apart today to replace the bulbs in my instrument cluster (replacing them with LEDs), and when I put the cluster back in, I have nothing on my gauges. Also, I get no lights when I turn the key on, except the battery (which stays on constantly now, despite my charging system being tested and passing), and the airbag light, which kicks on then back off like it's supposed to.
I've put the bulbs back to normal to see if somehow that was an issue, no luck.
My backlights/parking lights work fine, so I can see the gauges, but they aren't registering anything. I've cleaned the contacts with some rubbing alcohol, wiggles wires, etc. Any ideas?
Also, I was called into work halfway through and drove about 20 miles with the cluster removed, could that have caused an issue?
I've removed the negative battery cable for about 30 minutes to see if that helped, no luck.
