papp
- April 9, 2005
- Minneapolis, MN
- '97 XLT
Hey there Ford aFFectionate Friends From aFar. . . .
My stock 97 XLT 4.0 OHV 4x4 eXx is giving me some issues. (107k)
*Q* Moving slowly through the revs on the road or in Neutral is wonderful. Purrs like a Big FAT4$$3|) cat. But, when I give it the GO :fire: it misses and *slightly* boggz. I read and read, and did the following.
a. Cleaned the MAF with electronic parts cleaner from Checker Auto.
b. Vacuumed out the stock airfilter, which wasn't even really dirty - lots of light showing through.
c. Seafoamed an entire can through the PCV valve inlet on the side of the intake manifold. A decent amount of smoke.
d. Had the IAC replaced about 1.5 years ago when it was humming a bunch, so left that alone.
e. Carb and Choke cleaned the inside of the already rattly PCV valve.
f. Replaced the Fuel Filter.
g. Reset computer via terminal disconnect for 20 min.
Since this, it moves a fair amount faster, mostly after the fuel filter replacement, but you can still hear/feel it missing/bogging a bit when you step on it. Just feels like you're not getting that smooth accelleration.
I should also say that I've NEVER gotten a Code on this car, so that's good I guess.
Should I check my 02 sensors? Via what method? Or take a fuel pressure reading? Test my fuel pump relay? Drink margheritaz and just sell the car like it is?
I'm just trying to get it in top condition to sell (looking for around $4300). I drive 80miles a day, and the 14-17 I get with this on the highway is toooo expensive.
Thanks for the help in advance.
