- February 2, 2002
- 1998 Mountaineer AWD
Well on Friday my trans started to shift in and out of OD and drive erratically. The truck started vibrating a few days before. I decided I'd take it in to my local trans shop and have it looked at. They called and said my t case came loose from my extension housing and my trans was low on fluid. On the way to the shop i had a delayed/slippy reverse, so I assume the fluid was quite low. As of now they think the trans might very well be fine. Tomorrow they plan to change the t case fluid, reseal it, and run it without the front d shaft to see if the vibration is still there. They seem to think it's a joint on the front shaft. I'm hoping that
1. My t case isn't damaged due to improperly matched shaft and gears
2. I don't have to pay to have the t case put back on correctly, to only
3. Also have to rebuild the trans due to driving with low fluid.
If it needs rebuilt what are the updates the tranny really needs? Get rid of the scarf seals for the sized GM seals? My trans shop is pretty good about updated parts and whatnot, though I doubt they know about the sized GM seal kit.
