98 explorer 4.0 sohc freeze plug locations | Ford Explorer Forums
Ranolf24
98 ford explorer 4.0sohc
Hello,I have a serious coolant leak. Had a pressure test done they said it was the water pump but turns out it wasn't. There was a clear leak coming from the thermostat housing so I replaced that no longer leaks from there but it seems even worse now than it did before. The car sat for a couple months so I'm thinking freeze plug. If you could please tell me where they are all located pictures would be even better.
