98 explorer cruise control switch issue | Ford Explorer Forums
lrsuttles
Willow spring nc
1999 explorer xls
Replaced cruise control switches on steering wheel. Afterward the speed control light on dashboard is blinking on and off also dash lights went out.After reading some post I changed the switch on the master cylinder. Light stilling flashing. Any advice will help . Thanks
Did you disconnect the battery cable before starting the project. You may have blown a fuse if not. Did you get the connections backwards, not difficult to do.
Inspect the cruise control module/gear box
Above the washer fluid tank is the cruise control module sometimes I've seen the internal gears seize many Ford vehicles have a similar control module the only difference between vehicles is the mounting bracket and the PCB board the gear box part is interchangeable In my experience you can take the PCB board off remove the 10mm bolt holding it to the fender then remove 4 torx 20 screws then be gentle pull off PCB and the internal gears should move by hand
