98 explorer limited 4.0l sohc 5r55e issues | Ford Explorer Forums
lonewolf5030
bovill,ID
98 ford explorer limited
I have a problem that started with dropping out of gear and a really bad gear grinding sound coming from the area of the bell housing replaced the transmission and its still there but worse. with the wheels off the ground it grinds but they move slowly if you give it more gas the wheels stop moving and the grinding gets louder and faster and doesn't stop until you put it in neutral or park engine idles fine and revs fine in park and neutral as well also this appears to be the second replacement transmission can someone help me figure out the problem
Did you replace the converter?
