Blown98
- November 7, 2013
- Chattanooga, Tennessee
- 1998 Explorer 4.0L SOHC
Hey guys, it's been a long time since I've been on the forum. Hope all of you have been well!
I'll jump straight into it.
Funny story: About 5 months ago, I had to replace my o2 sensors. No big deal, except that I forgot to reattach the sensor bracket to the transmission. Well, I hit a bump driving about 2 weeks ago, the o2 sensor wires touched the exhaust, shorted to ground, and blew the fuse that also coincidentally controls the transmission. I had horrific torque converter shutter, terrible time trying to get it to move, etc. Naturally, I did not check the fuses. I was convinced I had lost a solenoid, computer, harness had broken, etc., as the codes we pulled were all electrical in nature(duh, it was the fuse). Anyways, after verifying that the computer, all solenoids, and harness were in spec/working order, we discovered the fuse was blown, after dropping the pan to verify things.
Now, things have been great since the fluid was changed. It blew my mind how clean this trans pan was/magnet at 243,000 miles (last service was done at 100,000 miles). I did a partial drain and fill at 205,000 miles when I drained my converter after an engine replacement. But still, It had less material stuck to the magnet than my 100,000 4l80 did.
HOWEVER, my long time issue with hesitation going into drive has gotten horrendous. I never had an issue with it NOT going into drive(it would just hesitate for about a second then kinda drop rpm into drive), but now, if it is cold(sudden cold snap in the south has us at less than 40F every day), and I do not fully warm it up before driving, I do not have any forward gears. Reverse continues to be and has always been immediate. I am assuming that the new fluid is much thinner than the old fluid when cold and I do not have the correct amount of line pressure, most likely also caused by a lazy EPC and blown valve body gaskets.
As this has only happened in the past 3 days, I have not had the time to experiment with what does and does not fix this. I have made sure to warm it up fully after it has happened twice. I did notice that if it revved to 2,000 rpm a few times(as in 2), it will go into drive. And drives fine with no other issues.
The TSB for the 5r55e valve body gaskets was never done. I am assuming, like I have for awhile, that my valve body gasket is blown and that the EPC is very lazy/needs replaced.
Am i correct in assuming that I need to follow the rebuild diary found here to fix this problem? I know there has been some debate on which kit and parts to buy, so is the parts list listed here everything I need to fully rebuild this valve body? I would like to purchase everything in one go and complete the fix ASAP.
Thanks guys.
TL;DR:
1998 4.0l SOHC 4x4 5r55e with 243,000 miles and new fluid/filter will not engage any drive gear unless the vehicle is up to operating temperature. Reverse engages normally as before trans service. Drives fine with normal shifts in every gear once in drive. Suspect blown valve body gasket and failing EPC based on research from the linked articles.
Thanks guys.
TL;DR:
