Solved - 98 explorer /mountaineer 4wd high and low lights flashing and power window fuse blows | Ford Explorer Forums
Solved 98 explorer /mountaineer 4wd high and low lights flashing and power window fuse blows
Prefix for threads that contain problems that have been resolved, and there is an answer within the thread.
Sdr500
Farmington
1998 explorer/mountaineer
Ok so of you have both 4wd lights flashing and power window fuse keeps blowing check you wires between door and truck for a break mine was a orange and green wire problem solved just fix the broken wire not much room to work with so just be patient with yourself
