Flashing 4WD high and low lights. | Ford Explorer Forums
Arkbird443
St Louis Missouri
1999 Explorer XLT V6 4.0
As said in the title, the 4WD lights flash often several times. Also, the interior lights and automatic windows don't work. I think it's the accessories delay relay. I have bought a relay. I have tried replacing the relays under the hood and the problem continues. I have also changed the fuse. Please help! I have a 1999 V6 XLT SOHC.
I've seen 4X4 indicator lights flash in response to improper signals from the ABS sensors. Interior lights problem, no clue, may be unrelated.
When I wanted to spin only rear wheels under power, up on jack stands, I pulled the two fuses which feed the 4X4 electronics, thus disabling 4X4 AUTO. While removeds the 4X4 LOW indicator flashed as well as the ABS indicator being on. This went away when fuses were replaced.
Suggest looking into the ABS system, see if any trouble codes exist. imp
