crawfr1312
- May 8, 2001
- Trainer, PA
- 98 Sport 4WD SOHC
Anyone had problems with the SOHC motors such as Low Idle, Stalling at stops, bucking like the fuel filter is clogged between 35 - 50 mph? Had it in the shop for two days. They said it sounds like it had a vacuum leak but couldn't find it. They also said it may be the MAS, but they didn't want to guess at $190.00 part. Plugs, fuel filter were changed a few thousand miles ago. Also, does this engine have a PCV Valve on it? I saw it on the vacuum diagram, but can't find it anywhere. There are no pictures or info in either Haynes or Chiltons on where it would be on the SOHC, only the 5.0 & 4.0 Pushrod. Help..................Thing runs horrible.........Wifes been complaing for months.
