Anthony17
- June 5, 2015
- Radford, VA
- 2000 Explorer Eddie Bauer
Hey all,
So I've been doing a ton of reading on the issue I've been having, and haven't really found the solution yet. I have a 2000 EX EB 4.0 SOHC with 230,000 miles with rebuilt transmission. Was very well maintained. On cold starts only (1st start of the day), my truck has a really low idle. It bounces between 300-500 rpm, and bucks/shakes, the interior lights/dash lights flicker to the shaking because of the low rpm. After about 10-20 seconds (depending on how long it sits) it will shoot up to 1500 rpm and settle back down to idle. Then it is fine for the rest of the day. I'm worried when the winter comes that this issue will be worse.
When I try to give it a little bit of gas, it revs up to 1500-2000 rpm and I can't seem to give it just a little gas. To me, this sounds like a vacuum leak. It seems the supposedly bad gaskets need to get warm and expand on initial start of the day, then the warm summer days do the rest of the work. It's been in the 60's in the mornings so far. I have only had it since June of this year, so no winter weather with it yet.
On to what I've replaced or fixed related to engine components:
I tried to replace all the common problem components (as it's old with many miles and I don't know when these parts, if ever, have been replaced) before I came to ask more questions. I also ran sea-foam through a tank of gas.
Right now I am currently waiting on a new downstream O2 sensor (to fix current CEL), IAC gasket and upper/lower manifold gaskets. Could either of these be my potential fix? Maybe it's the ignition coils? I know those manifold gaskets are also a common issue for rough idles, but I'm not sure if it attributes to my exact issue. Any ideas? Am I going in the right direction?
- New IAC valve
- Spark plugs and wires
- ECT sensor
- Thermostat
- Air filter
- Oil filter and oil change
- Fuel filter
- Cleaned throttle body
