Justin_
- March 30, 2020
- Missoula
- 98 2-DR Sport 4x4 4.10
- Callsign
- KJ7IKI
Hey guys, im back to working on my 98 SOHC w/auto trans again.
This time im looking to address heat.
Recently I took a 2000 mile trip down to Las Vegas to attend a cyber security conference and had a great trip. The truck ran well with one exception, it got HOT.
For a better part of the trip between Salt Lake City and Las Vegas I had to keep an eye on the thermostat gauge to make sure I was not overheating. Most of that part of the trip I ran between 'Above normal' and 'Uncomfortably hot.' I did manage to keep the gauge below vertical the whole time, but had to slow down quite a bit at times. I wouldn't blame the engine as the ambient air temp was as high as 118F, the AC was all the way up, and the highway was going 80 on hills, but I would like to minimise this.
I have also noticed this once closer to home when I had the cruise control set at 90/95 and it charged right up a steep hill at full tilt. Im sure my 4.10 gears are not helping me here.
In the last year or so I replaced the thermostat+ring, rad cap, and coolant. When I replaced the coolant it was just because I had to pull the rad during the body swap. The coolant was super clean when I drained it so I don't think there is much/any buildup in the engine.
This has lead me to looking at new/upgraded rads. I don't have much experience here (Well, there has yet to be a car thing that I have had experience on when jumping into it
) but it looks like I should try to grab an all aluminium rad with 2+ cores. I do know that there is an aftermarket trans cooler installed so I don't need to worry about trans line compatibility.
Should I just go for an all aluminium 4.0 rad, or is there any advantage in using a 5.0 rad?
Is there anywhere that sells a trans-less rad, or is that even something I would get better performance out of?
Is the stock rad copper/brass? Will I get better performance out of a typical aluminium radiator with plastic tanks, or should I just go full aluminium?
I see that Radiator Express has an all aluminium rad. It's a bit expensive at $230+$25 shipping. Im not against spending the cash, just looking at comparing my options before I do.
A few other things to note, I do not have a fan shroud. There was never one on the truck from when I got it, and it has a 3" BL so I don't know if one would fit. Also I have a winch blocking part of the rad for what that's worth.
Please do let me know if I am looking in the right direction.
Radiator 1998 Ford Explorer - 4.0 Liter V6 245Cid Radiator 3 Row, Ohv Engine (Non Stock Upgrade) | Radiator Express
Rush delivery of Radiator 1998 Ford Explorer - 4.0 Liter V6 245Cid Radiator 3 Row, Ohv Engine (Non Stock Upgrade)from over 100 nationwide locations. Order online or call 1-866-723-3977
www.radiatorexpress.com
