98 XLT Heat Question | Ford Explorer Forums
jagarundi
Brooklyn,NY
1998 Explorer XLT AWD
My 98 XLT takes a while before the heat gets hot. Should I check to see if the thermostat is stuck open or should I check for something else?
My 98 takes awhile also. Just make sure it's full of anti-freeze. That is about all you can do I guess.
Doggie
Mine Heats up right away. It was 6 degrees above and it warmed up quick. Do check the open thermostat. Good luck.
