98ExplorerGuy
- May 12, 2007
- 1998 Explorer XLT
It's been frigid in Connecticut this year with many sub-10 deg mornings; not sure if that relates to this issue but I put it out there just in case.
I drive about 22 miles each way to work; virtually entirely on the highway in the mornings and then 17 highway/5 local in the afternoon. For most of the past 10 days, I have had perfectly good heat for the entire morning commute but in the afternoon I start out with good heat which then suddenly goes cold right around the time I get off the highway. I drive to my wife's office, turn off the engine and go inside to wait around 15-20 minutes for her to finish up. The remainder of the drive home (5 miles) I cannot get any heat at all. Mind you, if I turn the temperature control to full cold, the air output definitely gets colder (well, seems like it, anyway) but on full hot it does not reach anything even remotely warm - just not ice cold.
This morning's commute was something different however. Absolutely ice cold air the entire trip until 1/2 mile from the office when it warmed up just a bit (could have been my imagination; I was quite frozen at that point).
Any thoughts as to the likely culprit, given the on again/off again episodes described above? I am particularly curious about the recent rides home where I start out with full heat and then suddenly lose it 15 miles into the drive.
I have lived without air conditioning for several summers (bad compressor) but don't think I can last the rest of this winter without heat.
