unpredictable1
- July 16, 2001
- AB, Canada
- 99 Explorer Sport
My 99 Sport has a problem with the rear hatch key button that also opens the rear glass access. You can't lock it. It opens and closes securely without issue but if you lock the truck, you can still press this key button on the hatch to still gain entry. The main hatch locks as it should, via remote and using the key but the button will still let the glass open.
From searching it appears it's the button itself but I can't seem to find a way to just disable it. I've taken the panel off and checked all the linkages etc, everything is connected and moving freely, and it's like pushing the button completely overrides the fact it should be locked. I can also still use this key hole to lock and unlock the main hatch without issue. (this indicates the linkage between the actuator and rest of locking mechanism is fine.
Several months ago I replaced the rear hatch door lock actuator as it was developing the issue where you sometimes couldn't open the main rear hatch. As part of that repair I greased all linkages and the button itself. I'm willing to bet this rear glass has been like this a while (it was seldom used)
