'99 XLT Serious Vibration Issues | Ford Explorer Forums
TheBigEasy
Far Out There
'99 XLT
Hey guys...
Need some help. I have a '99 explorer (v6) with 94,000 miles. I have a serious vibration problem when accelerating. Worse as the speed increases. I have had my tires rotated and balanced with no luck. The truck is aligned and the tires are less than two years old. I feel the vibration throughout the truck...steering wheel, gas pedal, seat (front and back). When I let off the gas (coast) the vibration stops and all is quiet. Please let me know if you guys need any more info to help me pin point the problem. Thank you so much for the help... :( :( :( :( :(
TheBigEasy
PS...Awesome site you have here :thumbsup:
Bump.
Driveshaft ujoints?
Torque Converter
check your actual driveshaft bolts. Then take off that little 5th helper shock in the rear, they cause bad vibrations when they go bad
