300nz
- December 21, 2005
- Florida
- '99 XLT
Hello all. I purchased cam washers and 1.5 inch lowering blocks.I have been searching on this forum for hours searching thru the torsion twist threads but can not find what I'm looking for so here goes...
I have a 99xlt 4x4. The main question is where is the proper place to measure the suspension height before and after the twist in the front and rear block addition? Are there different alignment specs when lowered vs. stock? The camber washers are +/- 2 degree from NAPA. It looks like they just get installed on the nut side of the control arm bolts after removal of the stock washers. Do I have to do anything with the other side of the bolts ( washer removal) ?
Once all is installed and adjusted, is there a way to set the camber near enough to spec. to get to the alignment shop?
Thanks to all for the help.
