I have been thinking about switching to synthetic. If I do, can I just change the oil like normal, or do I have to flush everything out real good. Will it hurt if a little dino oil gets mixed with synthetic?
Originally posted by Gonzo I have been thinking about switching to synthetic. If I do, can I just change the oil like normal, or do I have to flush everything out real good. Will it hurt if a little dino oil gets mixed with synthetic?
Every syn oil I have seen states that the syn oil is 100% compatible with regular (dino) oil. You could mix them together if you wanted (I'm not suggesting that you do though) and it should not cause any issues.
re: Flushing with new oil
I have done this when opening the engine up (i.e. changing the valve cover gaskets or replacing the timing chain) but I don't think it is necessary for a normal oil change. It won't hurt anything, but I don't see that much of a benefit either.
re: Using a Oil Flush product
I have seen that some people on the Oil Board have a product that they like, but again, if you are changing the oil regularly and using quality oil (esp syn oil which is high detergent) I'm not convinced that there is a big benefit to the oil flush products.
