A\C: Air blow thru vents, then defrost | Ford Explorer Forums
MtDew
Northern Indiana ***Unless your the lead dog, the view never changes!***
2003 XLT Explorer 4.6 V-8
Hey Gang,
I have a 2003 EX XLT with the 4.6 V-8. When I turn on the A\C it keeps the fan only seems to have two speeds. High and low. Nothing in the middle. The air also alternates between the vents and the defrost vents by the windshield. When it alternates it apparently opens the outside air vents because the air blowing from the vents gets warmer for a bit and then gets ice cold again.
Anyone else run into this problem or have any idea what is causing it?
Thanks! :D
Turned out to be a vacuum line that had fallen off :D
