A/C blower motor switch. | Ford Explorer Forums
jwyow865
knoxville, tennessee
'96 xlt
I have a 1996 explorer xlt the blower motor only works on the 3 low speeds and high it does not work
blower motor doesnt whine or make odd noises works great other three speeds
i checked the resistor its fine
replaced the switch inside
checked the fuses and relays all are fine :thumbdwn:
is there an inline fuse or fusable link between switch and resistor?
thanks for any help
Welcome to this forum! I've moved your thread into the A/C & heater section. Did you use a continuity tester or a multimeter on the blower motor resistor? Sometimes you can't tell if it's bad just by looking at it. There could be a broken solder joint somewhere.
How did you check it? How do you know it is working? A replacement is cheap.
