A/C blowing high to low | Ford Explorer Forums
heath223
Columbus, Ga
98 xls, 04 xlt
My A/C in my 98 Explorer has started blowing slower when the engine revs. Example... I will have the A/C on high and it is blowing high then I start up a hill or pull off fast from a stop or just accelerate pretty good wile driving and the air flow slows or stops and a couple times it has even started blowing out the defrost vents.
I had the intake manifold/gasket replaced 6 months ago so could it be an issue with vacuum (if the controlls for the A/C work off vacuum)?
Thanks for that but mine is blowing from the vents and I can switch from vents to defrost fine it's just without making a change my fan blows slower or either something is going on with the vent selection and some air is being diverted elsewhere or to the defrost? but I have seen a couple times where it definatly starts blowing out the defrost then once I ease off the gas it will divert back to the vents.
If the Fan is really slowing down I don't have an idea...
If the air moves from the dash to the defrost when you lose vacuum then the vacuum ball or check valve must be having an issue.
~Mark
I did check it and it is not the motor slowing down. When the air decreases at the vents I can feel a little air coming from the defrost. I guess I need to start checking for vacuum leaks? Could this have anything to do with having the intake manifold replaced, other than if they damaged a vacuum line when they changed it.
