AHenry014
- July 30, 2018
- East Haddam CT
- 2006 Mountaineer Premier
2006 Mountaineer with auto climate.
Now it may just need a for real recharge, but ill explain the symptoms and see if anyone has any other input. I just inherited my grandfathers 2006 Premier and drove it home from western PA to central CT. I knew it had an issue with the a/c but i wasnt sure exactly what the issue was before i got there. I went straight from his house to advance auto where i picked up a can of r134a. The compressor was kicking on and off before i started, so i knew it had at least enough charge to do that. I was able to get some of the can in the system where the front started to blow a little cooler than ambient air. I then tried the rear a/c and found it to blow nice and cool. We drove it home like this, using the rear to keep the cabin cool with the front vents merely making a light breeze for us.
Now i briefly read up on the blend door actuator issues and have no problem swapping the actuator itself if thats the problem, but i wanted to check here first.
Thanks all.
Thanks all.
