A/C Condenser removal? | Ford Explorer Forums
chris070780
91 XLT
I desperately need better flow to my radiator. I think I have to remove the radiator do remove the condenser. My question is do I have to remove the clutch fan to remove the radiator?
you can pull the radiator out without removing the fan,i did it on y old 92 i had,just make sure u drain the radiator first,there is a little drain valve on the right hand lower corner of the radiator,or do what i did,put an external fan on it,my temp stays around the o on normal
