A/C disconnecting randomly | Ford Explorer Forums
Ahmed Fadel
Riyadh
2010 Explorer Eddie Bauer
Hi . I have Ford Explorer 2010 eddie bauer with A/C disconnecting randomly without any reason . The air comperssor itself work very well. But the problem in disconnecting.
It's disconnecting in various situatuion . Some time when I operate the car at morning keep disconnecting for about 15 minutes then operate again then disconnect for about 5 minutes then come again. So any technichan I Ask they try to pour some water on the BCM unit and the A/C come to work. so all they told me that it's the computer unit of the car is dying and need to be replaced.
So does forscan program have option in programming to fix this issue please ? or any clue to solve it ?
Have you had the pressures in the A/C system checked? You didn't mention that.
Just when you driven does this happen?
Check the compressor connector pigtail.tends to became brittle because of the aging
Rockauto sells repair kit for this issue
