a/c evaporator coil cleaner | Ford Explorer Forums
myklt8
Roanoke,Texas
'97 XLT 5.0
Guys,
I had read an article a few weeks ago that talked about a foam cleaner that you injected into the evaporator box thru a fitting (on the drain tube?)
i found a few sites where dealers are doing this, but this was something you could do at home. Any ideas on what this stuff is or where I could find it?
Thanx
Michael
post a link to that and i'll tell you if you can do it at home or not.. seeing hows i am an a/c tech
The first time I searched, all I found was a dealer service link. Searched again and found this http://www.dwd2.com/
Worth a shot?
ok gotcha sure you can use them all they are : EvapCoil Cleaner.. any suppy house will carry the same stuff cheap.. it all foam.. the only advantage to that stuff might be the packageing.. i.e you dont have to mix yourself.. buy you should be to find it at a parts place for a/c equipment or a service place will diffinetly have some...
Thanx
