huntman58
- February 13, 2007
- Fremont calif.
- 2013 Dodge Advenger
Okay I did a no no years ago and did a cheep r12 to r 134 change over. It worked for over 4 years but now I have no air. This happened over the last two years with it slowly getting warmer and warmer starting at idle only to any time in the end.
I now know I did it wrong and I know better now.
any hoot I just tried to recharge it after replacing the accumulator and the orifice (yes I know I should have flushed but I did not thinking if I could get a year or two that’s all I needed) well after adding the accumulator and orifice then changing the o rings on the compressor manifold and any of the pipe joints I opened it will not hold any charge or vac at all.
I do have gages and did take a reading before starting all of this and this and they were
Static
Low= 50 psi
High = 50 psi
Running
Low = 27 and 47 psi (points of compressor kick in and out)
High = 120 psi and dropped to 50 as compressor kicked in and out
After repairs static 60 each then bleed off with in 5 mints.
Run 150 high
Low 26 and 50 psi also dropped to 0 after 5 mints.
Can not find any leak at all or traces of one!
Were is the most leak prone area on a 93 explorer?
How easy is it to flush a system with out any special tools but an air compressor (small 5 gal tank one) and a air gun?
would I be better to just forget it being I can not spend over $100.00 more into fixing it over what I have already spend
Bought already
Gages
r134
Pag 46 oil
O rings
Elec. vac pump
Accumulator and orifice (blue)
so best Ideas and or tell me to just forget it all things welcomed
thanks ahead of time for your time. o ya if any one is in the Fresno area and can help me find the leaks your welcome to do so
Static
Low= 50 psi
High = 50 psi
Running
Run 150 high
Bought already
Gages
r134
Pag 46 oil
O rings
Elec. vac pump
