A/C PROBLEM....can anyone help? | Ford Explorer Forums
dougiiefreshh
2003 Ford Explorer
does anyone know whats wrong when the A/C doesnt get cold? the A/C button turns on and all but the air doesnt get cold...it stays warm....
could have a leak somewhere and all the freon is gone. thats the logical answer. you need to have it looked at by a a/c certified mechanic unless you know someone with a a/c gauge to hook up and your pressure.:cool:
Just thinking out loud - go start the car. Turn on the a/c (make sure its' on, sometimes when its' bright, I can't see if the light is on or off on the button), and locate the compressor.
It should cycle. The belt should always be going, but sometimes the compressor clutch will kick in, and the front face of the pulley will spin. When the clutch is out, the front face won't be spinning even while the belt is moving.
Many things can cause no cold air. Freon loss is one reason. No freon = no cooling even if everything else is right on. Easy test, I haven't looked at mine, but many A/C systems have a so-called "sight glass" near the receiver / dryer assembly. Looks like a fitting with a small circle window. You should see the occasional bubble when the clutch is in. No liquids blowing by, no bubbles, no freon.
Then, there is a pressure switch that can sense freon loss. If it detects a loss, it can keep the clutch off to keep from burning the compressor up. If that switch goes bad, the compressor won't run (my test at the beginning).
If the wiring to the switch is broken, or looks good but is corroded inside, no lockup voltage to the clutch = no cooling. If the wiring to, or the clutch is messed up, = no cooling.
Seriously, if the belt is broken = no cooling. My brothers non-Ford SUV has a dedicated A/C belt. It really was that simple.
If you have an EATC (fancy controls inside), a failure at any of several points = no cooling. If you have the basic system, if there is a vacuum loss, the flap over the evaporator in the plenum won't flap over = air, but no cold air.
BE CERTAIN before you buy one of those "I done fixed it myself" kits, that you know for a fact what refrigerant you are using. There are retrofit kits, so you think you are using one thing, but actually you are using another.
Good luck!
-Shawn
If you can rent a set of manifold guages I'd suggest checking the pressure on your R134a system. harbor freight currently sells an inexpensive set for $39 currently at their stores. I'd suggest buying it and monitoring the high & low pressures. Getting a baseline pressure reading can help determine the cause, especially if you notice the compressor is cycling alot or if the compressor isn't even running. If your getting 35 to 40 psi low side and 150 psi or above on the high side and still the cab isn't getting cold it could pinpoint to a dirty orifice valve, compressor issues, etc. Definately start off with a set of guages. Its a must for any AC work.
