1970mach1
- February 22, 2013
- Decatur, GA
- 2005 Ford Explorer
The 2004 Explorer that my daughter has is having a cooling issue. I check the freon level and it is good. The passager side vents blow really cold air around 20 degrees. The drivers side vents blow air around 70 degrees. It does not have dual temp controls.
It is odd the two vents in the middle of the dash are side by side. The one on the right blows ou 20 degree air and the one on the left blows ot 70 degree air.
The rear AC unit blows out cold air also.
Is there a seperate temp sensor for the divers side vents????
Thanks for the assistance, Mick
