elrynon
- January 30, 2009
- Winter Haven, Fl
- '00 Eddie Bauer 4.0 SOHC
This is for a 2000 ford explorer eddie bauer with R-134a refrigerant.
I'm getting ready to replace all the O-rings on my ac system because I have a leak on the back of the compressor and one on the hi tubing. A few questions I have are am I ok just replacing the o-rings and being done with it (as long as there aren't anymore leaks anywhere) or do I NEED to replace anything else?
I've spent about 2 days reading posts about a/c repair and talking to multiple people and now I'm on information overload.
Some people say to replace the accumulator and orifice tube as well and some people say just replace the o-rings and be done with it. Another note is when I pop the hoses off to replace all the o-rings what is the likelihood that I'll be losing oil for the system? There's no refrigerant in the system as it's all leaked out. I have just seen people talk about needing to put oil back in and once again some people saying just replace the o-rings and go.
I'm also curious to those who have torn into the system is it JUST o-rings or are there seals as well? I looked on autozone and depending on where you search you get a different answer.
On one page it just shows o-ring kits but on some other pages there are kits with o-rings AND seals. All I had "planned" on doing was where everything connects together. Ends of hoses, etc.
And lastly once I get this all done and I take it into a shop to get it vacuumed and then recharged what's the best order to get it tested to make sure I got all the leaks and did everything right? Can they do a vacuum test of some sort first? Or will they have to vacuum it, fill it, test it, if there's a leak empty it again and start over from scratch.
I appreciate any help in my a/c endeavor. If anymore info is needed then by all means ask and I'll give whatever info I can.
