Green00
- December 29, 2008
- S.E Michigan
- 2000 Sport
Hi Folks,
I'm new to Explorers, so bare with me. :notworthy:
My GF has(I'm the fixer monkey) a 2000 Sport, 4.0.
I need to replace the O2 sensors, all of them. Do these need the O2 sensor socket to be removed or will an open/closed ended wrench work?
Also, when doing the spark plug/wires. Is there an easy way to get these wires done, I have far from small hands and it looks fun, to say the least. What should the plugs be gapped at? .40?
What should the idle be, warm on these? IIRC the idle is about 750-800? I'm sure a quick IAC needs to be cleaned if this is too high.
The rear wiper seems to only work in the cold weather, is there a known problem with these?
Any other known problems I should maybe look at?
I think that's it, for now. I've replaced so much on this in the past 1.5yrs I've lost track.
It has been a good vehicle..
Thanks for any input.
