a little help please | Ford Explorer Forums
badsun79
02 explorer
this forum looks to be a god send for the novice like me lookin for help thanks in advance everyone..
ok heres the problems.
1. 4x4 quit working fuses are ok.
2. aprox 10-12 sec delay for radio, power windows, wipers ect.
3. rear wiper also quit working.
and last but not least remote start will engage but won't follow thru with the start powers up and all then shuts down and tries again. any help would be fantastic........ thanks
Try doing a search (in the banner near the top) for your issues. You might have to do more than one search for each item to narrow it down.
You are in the right place for advice. These guys are great! Good luck and keep us posted.
Might want to provide some more info on issue #1? Like the when, how, what, etc... the truck is doing? Lights flash, codes read? Helps diagnose a little better...
Is the delay on the accessories when you start the truck, or after you shut it off?
thank you
it does it at start up, no radio, pwrwindows,wipers but gauges all respond as soon as you turn key on as far as the 4x nada zip zero push the button and nothing no dash indicator no noises nothing
also when the 4x quit it just up and quit one morn crap weather pushed button and no 4x used it the day before??????????????
shift motor, i just had a starter on another truck freeze up with this cold weather. . .hopefully its just frozen, can you warm it up in a garage.
If its not that simple then that motor could have burned out or there is a module too behind the glove box that fails too.
